JamesHun
úgy érzem a 750ti és i5-ös duóval nagy reményeim ne legyenek grafika terén :S
SeriesX: JamesSHun
JamesHun
valami patchet szedd le
562 mbén PC-n is xbox kontrollerrel játszom
hidd el nagyon sok játékhoz jó azGépet rádugtam a TV re USB kábel elér az ágyig
1-az egyben olyan mintha a One on játszanék csak szebbThe Witcher 3: Wild Hunt - Patch 1.04 changelog:
Rebinding any key is now available after switching Unlock Bindings option in Options \ Key bindings submenu.
Corrects an issue in the dialog system that might rarely cause dialog looping in scenes.
Fixes an issue with incorrect behavior of Wild Hunt warriors after they were under the influence of Axii sign.
Corrects a bug causing spontaneous combustion of gas clouds.
1280 x 720 resolution is now properly displaying as valid resolution option.
Fixes boat stuttering in cutscenes.
Texture rendering quality for high / ultra presets improved.
Further improvements in NVIDIA Hairworks performance.
A few additional Gwent cards are now available in the Prologue area.
Fixes an issue where users with usernames using non-latin characters were unable to import saves from Witcher 2.
Overall stability and performance improvements.
Fixes related to alt + tabbing and minimizing game window.
Game icon updated.
Enlarges the size of the loot pop-up window in the UI.
Fixes an issue where, in certain circumstances, the comparison window could be displayed outside of game borders in the UI.
Upgrading set items no longer destroys sockets.
Small UI tweaks for Gwent.
Corrects some missing translations in localized versions.
The Witcher 3: Wild Hunt - Patch 1.03 changelog:
Improves stability in gameplay and the UI
Improves performance especially in cutscenes and gameplay
Fixes grass and foiliage popping that can occur after density parameters change
Improves Nvidia Hairworks performance
Boosted texture anisotropy sampling to 16x on Ultra preset
Sharpen Postprocess settings extended from Off/On to Off/Normal/High
Improves menu handling
Improves input responsiveness when using keyboard
Corrects an issue with stamina regeneration while sprinting
Fixes a cursor lock issue that sometimes occcurs when scrolling the map
Generally improves world map focus
Corrects a bug where player was able to fire bolts at friendly NPCs
Corrects an issue in dialog selections
Corrects some missing translations in the UI
Minor SFX improvements -Blood particles will now properly appear after killing enemies on the water
Rostan Muggs is back
Adds Japanese language support (text and voice-over)
Adds Korean language support (text only)SeriesX: JamesSHun
JamesHun
most komolyan azért sírtok mert 15-ös szinten a 4-es szintű küldetésért nem kaptád 100 xp-t?
Én sem kaptam jó pár küldiért ezért is estem neki most elsődlegesen a még épp hogy zölden jelzett küldiknek, hogy ne fussak ki belőle lehetőleg
De ha nem jön érte XP sem érdekel a fő küldik adnak rendesen és majd kijavítják
BF4 fél év után is bughalom volt és még most sem tökéletes a hitbox pedig lassan 2 éves a játék
Szedd össze az erőhelyeket azt megkapod tuti, vagy csak kalandozzál ha már RPG-t vettélSeriesX: JamesSHun
JamesHun
egy gwent játékostól csak 1 lapot lehet nyerni?
ez a felperzselés néha miért nem a legerősebb lapot zúzza szét?
És miért az enyémből néha?SeriesX: JamesSHun
JamesHun
válasz FireKeeper #4716 üzenetére
az a hős lap amit lerakáskor ilyen kis izé körbefut?
Azért jó lenne ha jelezné, hogy kivel játszottam és nyertem el valamilyen kártyáját
Alig van még jó lapom, pedig 23-as szinten vagyok és minden lapot megvettem amivel találkoztamSeriesX: JamesSHun
JamesHun
na ezt nem értem
kártyázok és van egy kártya ami elpusztítja az ellenfél legerősebb közelharci egységét ha a ostrom gépeinek együttes értéke 10 vagy többmost vagy fordítási gond van vagy nem tudom, mert 0 ostromgép volt kijátszva mégis az ellenfél mikor kijátszotta a lapot meghaltak az egységeim
se nálam se nála nem volt ostromgép :SSeriesX: JamesSHun
JamesHun
JamesHun
a vérfarkasos ligetesnél hogy lehet véglegesen kiiktatni a rohadékot?
ott van a barlangban és már más küldetésrésze nincs a küldinek, csak ez, de ha kaját adok neki feléled másnap, ha megölöm feléled másnapSeriesX: JamesSHun
JamesHun
válasz Ted_Beneky #5433 üzenetére
akkor itt lesz a gond
én leöltem őket, mert pimasz volt, de mikor a hullákat fosztottam ki egy őrnek nem tetszett és elkezdet kergetni
akkor ott van a lényeg még a kikötőbenSeriesX: JamesSHun
JamesHun
melyik jelet érdemes felhúzni a végső csatákra?
tartalékoltam pár upgrade pontot, de nem akarom hülyeségre elkölteni
26-os szinten vagyok, így gondolom "hamarosan" jön a vég
most kell a csapatott összeszednemSeriesX: JamesSHun
Megkérnénk minden topiklakót hogy a játék történetéhez kapcsolódó hozzászólásoknál használja a Spoiler kódot!
- Gyúrósok ide!
- Router gondok
- Vírusirtó topic
- Xbox tulajok OFF topicja
- Motorola Edge 30 Neo - wake up, Jr...
- Ej-Ha! Lenovo ThinkPad P53s Szép Home & Business Laptop -70% 15,6" i7-8665U 16/512 Quadro P520 2GB
- Új Lenovo ideapad 5 Pro Prémium Ultrabook 14" -30% Bivaly Ryzen 5 5600U 8GB 512GB 2,2K RADEON 2GB!!
- iPhone 13, 128GB, starlight, kártyafüggetlen, 88% akku
- Tyű-ha Lenovo Thinkpad T15 "Golyóálló" Üzleti Laptop 15,6" -50% i7-10510U 4Mag 32GB/512GB FHD IPS
- Új 2K AM5 Gamer PC R5 7600/RTX 3070 8Gb/2X8Gb 6000Mhz DDR5/500Gb SSD M2/700W 2Év gari
